View a Report
  1. From the Analyze ribbon, Results tool set, click the Reports icon.
  2. Select a report from the report list.
  3. Under Model, select Append, Overlay, or Replace.
  4. Under Overlay options, select Auto fit plots or Auto color plots, if desired.
  5. Click Apply.
    The report is appended, overlaid, or replaced.
    If a report definition already exists, a message is displayed with the following options:
    Overwrite
    Existing definitions are overwritten by new matching definitions, one at a time.
    Overwrite All
    All existing definitions are overwritten by the new matching definitions.
    Stop
    The operation is aborted.
