To visualize road graphics in MotionView, you must open the
Road Tools dialog located under Vehicle Tools.
Figure 1. Road Tools Selection Menu
From the dialog, select the desired road file. The crg files much be chosen directly
instead of providing the rdf containing the crg. All of the road types mentioned in the
above section except 3D Cleat can be visualized.
Figure 2. Road Tools Dialog
In the above shown road tools dialog, the road file path must be chosen as shown. Road
Sampling can be changed as per user requirement to reduce the time for producing
graphics.
Figure 3. Road File Selection
The [GRAPHICS] block as described in each road module has to be added for customization of
visualization.
Flat
In the case of a flat road type, a checkered grid is created. The grid size is obtained
from the LENGTH and WIDTH value available in [GRAPHICS] block. The square size is obtained
from the ROAD_INCR value.
The road’s origin is shown by the marker in the figure below. If the ROAD_INCR is positive,
the grid is created in positive x direction. If it is negative, the grid is created in
negative x direction.
