Add and Select an Entity Using Geometry
- Point
- Vector
The Graphic entities that allow such operations are: Cylinder, Box, and CADGraphics.
MotionView is a general pre-processor for Multi-body Dynamics.
A multibody system study generally involves the following broad steps. The following sections give a brief introduction on using MotionView and the related HyperWorks products to conduct such a study:
Open and save model files, import/export models, and import/export a solver deck.
Learn more about MotionView model entities.
MotionView supports and encourages a modular model building approach. Different entities can be aggregated into containers, thereby arranging a model into a collection of different assemblies or sub-systems.
A collector is a yellow button on a panel that enables you to select an entity type either graphically or from the topics/motionview/collectors_select_entity_dialog_r.html.
The Select an "Entity" dialog allows you to change the entity in a collector.
Explore data entry in MotionView.
The expression builder allows you to enter expressions in text boxes without extensive typing and memorization. It can be used to construct mathematical expressions that are a function of the model parameters.
MotionView contains an implicit variable called SolverMode. In MDL, SolverMode can be used in an "if" context to define topology (include Templex templates). MotionView retains the "if" result for both cases so that when you toggle the solver type, the associated text becomes active within the user interface.
Batch mode allows you to generate a solver input model file from an MDL model file and run the solver job without starting the MotionView user interface.
The Export Data dialog allows you to export your data to an Excel or text file.
The Data Summary dialog displays model data in a table that can be edited.
Coordinate systems in MotionView can be oriented using a variety of methods.
Implicit graphics can be displayed for all applicable entities, allowing you to visualize their location and orientation.
Check Model searches for unresolved references and invalid data in the model. If errors in the model are detected, it is reported in the message window that is displayed when the check is completed.
The Create Deformable Surface From FEM macro enables you to quickly create a matrix of explicit markers to be used in defining a deformable surface.
Explore the various panels and tools in MotionView.
The Command Sets panel allows you to create command sets for the solver-command file. The command sets for a model are order dependent, since they define the contents of the solver command file.
Use the Forms tool to edit general data entry forms.
Use the Deformable Curves tool to create and edit deformable curves.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
