MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
Tires are critical elements to modeling a vehicle’s interaction with a road, with some tire models better suited to specific simulation domains.
Since computing tire forces and moments during a vehicle simulation is one of the most costly tasks, multi-threaded execution of tire models on a multi-core computer can substantially reduce the clock time for a simulation.
Altair HyperWorks integrates the Comfort and Durability family of tire models - CDTire - from Fraunhofer ITWM. The CDTire can be used in Ride and Handling vehicle analysis focusing on comfort, durability, and vehicle dynamics.
The FIALA tire model serves as the first stepping stone in full vehicle simulation because it is simple enough to be comprehended completely by the MBD analyst. Furthermore, the forces and torques produced by the tire/road interaction use a series of physically meaningful parameters.
Altair HyperWorks integrates MF-Tyre and MF-SWIFT tire models from Siemens (branded by Siemens as Simcenter Tire).
This tire is a FE based flexible tire solution from Pratt Miller that can interact with EDEM particles representing soil, sand, gravel, and so on. The tire model requires a finite element modeling file (.bdf) and other associated files. The AutoTire entity in MotionView provides a utility to generate the required mesh files from a CAD file. The tire can then be transferred to EDEM through MotionView-EDEM coupling interface. PM-FlexTire software is available as an Altair Partner product under the Altair Units licensing system.
User Written Tire models are implemented as user subroutines that compute the tire forces and moments, and the user road model is implemented as a subroutine that computes the road height at a given point.
The user written tire model is interfaced with MotionSolve using the Altair User tire interface.
The user defined tire model conforms to the TYDEX standard, therefore the received input and expected output is determined by the standard.
TeimOrbit Files are ascii files that organize data into blocks, sub-blocks, tables, and parameters with a few simple rules.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
