HyperWorks
HyperWorks
2021.2
  1. Home
  2. Multibody Modeling
  3. Vehicle Modeling
  4. Full Vehicle Events and Altair Driver
  5. Altair Driver File
    Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
  6. Longitudinal Controllers
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021.2
HyperWorks
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
    • MotionView Overview
      MotionView is a general pre-processor for Multi-body Dynamics.
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    • Preferences Dialog
      From the Preferences dialog, you can access various MotionView options for your model.
    • Vehicle Modeling
      • Build and Analyze Models
      • Vehicle Libraries
      • Components Library
      • Leaf Spring Modeling
      • Road Modeling
      • Tire Modeling
      • Full Vehicle Events and Altair Driver
        • Full Vehicle with Driver
          This section describes how to build events in the full vehicle model with Altair Driver. The new event user interface is supported only for models with Altair Driver. The interface exports .adf and .xml files and submits them to MotionSolve. Files can be edited or updated in the Event Editor. Eighteen event types are supported.
        • Event Types
          This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
        • Driver Overview
          The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
        • Controllers Library
          Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
        • Additional Altair Driver File Blocks
        • Altair Driver Mathematical Methods
        • Troubleshooting Driver Modeling
        • MotionView Interface
          Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
        • Altair Driver File
          • TeimOrbit Format
          • Altair Driver File Blocks
          • Open Loop Controllers
            Open-loop controllers define vehicle inputs directly without feedback (for example, steering wheel angle vs. time).
          • Path Controllers/Lateral Controllers
          • Demand Path
          • Longitudinal Controllers
            • Feed-forward Traction Controller
            • Feedback Traction Controller - PID Controller
          • Demand Signal
          • Additional Controllers
          • Engine Speed Controller/Gear Shift Controller
      • Road Tools
      • 1D Vehicle System Models
      • Update Model Utility
      • Aerodynamic Forces
    • Tcl/Tk Reference Guide
      Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Text Files
  • Tabulate Results
View All Altair Simulation Help
HyperWorks
HyperWorks
2021.2
  1. Home
  3. Vehicle Modeling
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
