sty
Sets the display style.
sty <argument 1> <argument 2> <argument 3> <argument n>
pid
Set the display mode for selected components.
edg all
Edge mode for all components.
Data type: string, string
edg <id>
Edge mode for the selected component.
Data type: string, int
edg <range>
Edge mode for components within the range.
lin all
Line mode for all components.
lin <id>
Line mode for the selected component.
lin <range>
Line mode for components within the range.
bou all
Boundary mode for all components.
bou <id>
Boundary mode for the selected component.
bou <range>
Boundary mode for components within the range.
som all
Solid mesh mode for all components.
som <id>
Solid mesh mode for the selected component.
som <range>
Solid mesh mode for components within the range.
soe all
Solid edge mode for all components.
soe <id>
Solid edge mode for the selected component.
soe <range>
Solid edge mode for components within the range.
mid
Set the display mode for the selected materials.
edg all
Edge mode for all materials.
edg <id>
Edge mode for the selected material.
edg <range>
Edge mode for materials within the range.
lin all
Line mode for all materials.
lin <id>
Line mode for the selected material.
lin <range>
Line mode for materials within the range.
bou all
Boundary mode for all materials.
bou <id>
Boundary mode for the selected material.
bou <range>
Boundary mode for materials within the range.
Data type: string , string
som all
Solid mesh mode for all materials.
som <id>
Solid mesh mode for the selected material.
som <range>
Solid mesh mode for materials within the range.
soe all
Solid edge mode for all materials.
soe <id>
Solid edge mode for the selected material.
soe <range>
Solid edge mode for materials within the range.
int
Switches the fringe mode on/off for internal displacements.
uno all
Apply X displacement of all nodes.
vno all
Apply Y displacement of all nodes.
wno all
Apply A displacement of all nodes.
dno all
Apply total displacement of all nodes.
off all
Switches the fringe mode off.
fun
Switches the fringe mode on/off for tensor data types.
nod all
Switches node related data on for all the nodes.
ele all
Switches element related data on for all the elements.
off all
Outputs
Nothing.
No error codes.
You are prompted if model/results are not loaded on the active window.
If no argument(s)/wrong argument(s) is supplied to the command, then the usage of the command is output based on the level of error.
Examples
Example 1
To set the edge mode for all components:
sty pid edg all
Example 2
To set the boundary mode for components 1, 2, 3, 5, 6, 7 and 8:
sty pid bou 1-3 5-7 8
Example 3
To contour the X component of the displacement:
sty int uno all
Example 4
To contour elemental results for the currently selected data type:
sty fun ele all
To use the sty function command, the data type should be set by using the rea function command.
