poIPost SetSectionDeformMode
Toggles the deformable section mode.
poIPost_handle SetSectionDeformMode deformable
HyperView Tcl Modify
This command toggles the deformable section mode.
Note: Deformable section cuts are planar at the simulation step when the deformable mode is activated. They stretch out of plane with the geometry in the simulations that follow. Planar sections cuts are always cut by a stationary (or undeformable) plane.
deformable
True
Enables deformable section cuts.
False
Enables planar section cuts.
Returns 0 if successful, otherwise an error code.
