poIPost SetBestViewTransparency
Sets the transparency level for all best views.
poIPost_handle SetBestViewTransparency transparency
HyperView Tcl Modify
This command sets the transparency level for all best views in the session.
transparency
Specify the transparency level between 0.1 and 0.9.
  • 0.9 (highest transparency) is the default level.
  • 0 is an invalid entry.
  • Numeric entries below 0.1 will be treated as 0.1.
  • Entries above will be treated as 0.9.
  • Non-numeric entries are treated as invalid.
To set the transparency level for all best views to 0.6:
post_handle SetBestViewTransparency 0.6
Returns 0 if successful, otherwise an error code.
