pltIPlot SetPhaseZeroAtTop
Sets the phase axis to begin at the top of the circular plot.
pltIPlot_handle SetPhaseZeroAtTop state
HyperWorks Tcl Modify
This command sets the phase axis to begin at the top of the circular plot (with a zero value) if you want to input a true value. This, in turn, sets the magnitude axis to be positioned vertically.
state
true
Sets the phase axis to begin at the top of the circular plot and sets the magnitude axis vertically.
false
Sets the phase axis to begin at the farthest point to the right of the circle and sets the magnitude axis horizontally.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot SetPhaseZeroAtTop true;
Keywords
HyperWorks
Tcl
Polar plot
Modify
