pltIPlot CutPhaseDatum
Cuts a phase datum.
pltIPlot_handle CutPhaseDatum datum, append_future
HyperWorks Tcl Modify
This command cuts a phase datum based on the user-input datum index. A phase datum is a line that goes from the center outward in the polar plot. It is used for comparison.
datum
The datum index (position in the datum list) that you want to cut.
append_future
true
Indicates the cut is added to memory.
false
Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutPhaseDatum 1 true;
Keywords
HyperWorks
Tcl
Polar Plot
Datum
Modify
