pltIPlot CopyCurve
Copies the curve to the internal clipboard.
pltIPlot_handle CopyCurve index, append
HyperWorks Tcl Modify
index
The number of the curve.
append
True
Appends the curve to other copied curves in the clipboard.
False
Replaces the contents of the clipboard with the curve.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName CopyCurve 1 0
myPlotName PasteCurve 0
Returns success or an error code.
