Animate and Record Results
Use the Animation Toolbar that appears at the bottom of the modeling window to animate and record results.
Animate Results
Animate the results of a forming simulation.
- To view a particular point during the analysis, drag the slider on the animation toolbar.
- The arrows to the right of the slider can be used to jump to any stage or
step in the operation.
Record Results
Capture the results of a forming simulation in .mp4 video format.
- The default behavior is continuous recording, but the recording stops automatically if the playback option is set to Once rather than Loop.
- To avoid capturing the workflow help in the recording, select , and in the Workspace category, clear the check box Show workflow help.
- To avoid recording the mouse cursor, on the animation toolbar, click the
step button
and press the Tab key to move the focus to the
record button
. Then press the Spacebar to start or stop the
recording. - Note that the video recorder captures everything in the region of the modeling window. Avoid obscuring or minimizing that window during the recording process.
Animation Shortcuts
| To | Do this |
| Play and pause | If the Play button is active, press the Spacebar. |
| Increment the slider |
Use the arrow keys to move frame-by-frame through the animation, or position the cursor over the slider and use the scroll wheel. |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
