Automating of the data exchanges process
Introduction
The implementation of a data exchanges process to carry out a multiphysics co-simulation requires a certain command of the python language use.
Due to the python language, the user will be able to turn the data exchanges process automatic by building up two command files.
To ensure the coherence of data exchanges it is necessary to implement a calculus precision test as well as an automatic synchronization between the two command files.
The rubrics below put forth the necessary information permitting the construction of the command files.
Contents
