Export of N dimensions data table
Introduction
A data table allows regrouping, in the same file (.oml, .txt or .csv). Data values contained in parameters (geometric or I/O parameters) and sensors after a parametric or transient solving.
The goal may be analyzing or reusing the data in another software.
Steps to export data tables
The steps to follow to export the data tables are:
  1. Launch the command through Data exchange > Export a data table
  2. Select the output parameters / sensors
  3. Select the file format (.oml / .txt / .csv) and the file name
    (For .oml files, enter the name of the files folder of destination. Each file contains one output parameter data)
  4. Select the interval of time / parameter controled via the scenario
  5. Select the type of values to export:
    • Current value
    • RMS value (on transient interval)
    • Maximum value (on transient interval)
    • Minimum value (on transient interval)
    • Average value (on transient interval). Remark: it is a statistic average value.
OML export for Altair ActivateTM (Lookup Tables ND)
