Result Preview: Multi-parametric scenario
Introduction
The results preview during the solving is also available when the scenario is multi parametric.
What abscissa?
- The time parameter if it is a transient study
- The last of the physical parameters chosen in the scenario if there is at least one physical parameter
- The last of the geometric parameters if there are only geometrical parameters in the scenario
Multi parametric display
The current curve is displayed with a continuous line.
The n-1 curve is displayed with an dotted line.
The other curves are shaded.
![](Images/ResultsPreview9_En.png)
Multi-parametric superimposition
Only the curves being calculated for a given set of parameters are superimposed. All curves already calculated (gray and dotted curves) are not displayed.
![](Images/ResultsPreview10_En.png)
