Result Preview: About
Introduction
- Advanced progress context (already existing before
Flux 2019)
accessible by the icon
- Results preview context (added since Flux 2019)
- A thumbnail for each quantity which can be displayed during the solving
- A representation of the solving algorithm with several progress bars
- A main viewer representing in large the selected quantity (red frame in the thumbnails below)
Manipulation of the window
- The size ratio of the different zones (main viewer / thumbnails) will remain proportional if the height of the window is resized.
- In the case of a resizing of the width, the size of the main viewer is stretched, on the other hand the dimensions of thumbnails do not change, but the number of thumbnails on the same line is adapted
- There is a movable separator between the main viewer and thumbnails which allows modifying the ratio between these 2 zones.
Life cycle
The solving window is persistent at the end of the solving. The user can thus analyze the curves. To access the postprocessing context, the user must close this window by clicking on the cross .
Limitations
- If the solving scenario is mono-step
- If the parametric distribution is activated
- If there is not real scalar sensors defined
- In the module Flux PEEC
