Radome (of Antennas)
The radome of the antenna is a protection of the radiating elements. The influence of the radome on the radiation of the antenna is included in the pattern of the antenna – but in MASC the influence (mainly shielding) of the radome on other antennas mounted at the same mast is considered.
Figure 1. Example for the radome of an omnidirectional antenna (a) and a sector antenna (b).
