Configurations
![](../../../../../images/winprop/user_guide/aman/multiple_antenna_scenario_config/dialog_definition_local_env.jpeg)
Figure 1. The Definition of local environment dialog.
- Quasi-omni (mast configuration)
- Skew (mast configuration)
- Side-mounted (mast configuration)
- Antenna in front of a wall (wall configuration)
The difference between the first three configurations (quasi-omni, skew, and side-mounted) is only the angle between arm and antenna. But as you can define these angles, each configuration can be described by the mast configuration.
The Antenna in front of a wall configuration is different as the antennas are mounted on a wall instead of a mast.
