Altair WinProp  2021.1 Documentation
  1. Home
  2. AMan
    Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
  3. Multiple Antenna Scenario Configuration (MASC)
  4. Limitations and Assumptions
  • Release Notes
  • Get Started
  • Examples
  • Introduction to WinProp
  • Typical Workflow in WinProp
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • Optimization (OptMan)
  • Connectivity Manager (CoMan)
  • WinProp Utilities
  • Appendix
Index
  • Release Notes
  • Get Started
    The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
  • Examples
    The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
    WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
    View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
  • WallMan
    The WallMan component offers a convenient facility to generate and edit vector building databases.
  • TuMan
    The TuMan tool enables you to generate and modify tunnel scenarios.
  • AMan
    • Introduction
      Radio network planning tools rely on accurate wave propagation models to predict the path loss between two arbitrary points.
    • Multiple Antenna Scenario Configuration (MASC)
      • Limitations and Assumptions
        • Far Field and Near Field
        • Concentration of Radiation in a Single Point
        • Description / Definition of Materials
      • Configurations
      • Pattern of Single Antennas Used in MASC
      • Computation of Wave Propagation in MASC
      • Mathematical Modeling of the Elements in MASC
      • Example: Computation of a Quasi-Omni Configuration
    • Using AMan
  • ProMan
    The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
  • Methods
    WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
  • Main Applications
    In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
    The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
    The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
  • WinProp Utilities
    The WinProp utilities consist of the Launcher utility and the Updater.
  • Appendix
  1. Home
  2. AMan
  • Release Notes
  • Get Started
  • Examples
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • WinProp Utilities
  • Appendix
Index
