Inspire Studio version 2020 includes the following new features and enhancements.
- New Drawing environment
- New Design Table
- New Rebuild Surface tool
- New Rebuild Curve tool
- New Face Round tool
- New Rounded Polyline tool
- Updates to Sketching:
- Sketch objects: Made the visualization thinner to distinguish them
from curves.
- Polyline:
- The angle parameter is now relative to the previous segment
instead of the x-axis.
- If the first point is snapped to an existing end point, the
yellow reference lines for snapping
perpendicular/parallel/tangent are visible.
- Line: Revised to provide the same functionalities as the Polyline
tool.
- It is now possible to set the angle in addition to the
length.
- If the length or angle is entered, it stays locked until the
second point is picked (or is unlocked with Alt).
- The yellow reference lines can be made relative to another
sketch curve, by hovering the mouse over it.
- Splines: Made the handles for inserting spline points transparent,
as on NURBS Curve and Blend Curve.
