Die
Trim the binder and add a round to finalize the draw die.
- On the ribbon, click the Die Design tab.
Click the Die icon.
Click the Die subtool.
Select a binder.
To reselect a binder, in the guide bar, select Clear Selection , and then select a different binder.To confirm your selection, right-click.
Select a fillet method:
Method Description Edge Fillet Create a fillet using the Round tool from Inspire Studio. Do one of the following:
- To define the same radius for all fillets, click a fillet and enter a Radius.
- To define variable fillets, press Alt and click a blue dot to add a fillet location. You can then drag one of the arrows or enter a Radius.
Loft Fillet Create a fillet using the Loft tool from Inspire Studio. - Adjust the fillet approximation. Enter a value between 0 and 1, where 0 is a chamfer and 1 is a fillet with a small radius.
- Click the fillet to modify the Width and Angle.
