Spring TYPE4 - 1 DOF Spring (/PROP/SPRING)
Spring TYPE4 is a simple physical spring, physical dashpot or parallel spring and dashpot.
Figure 1. Spring TYPE4 - Time Step
Critical spring time step ensures the stability of explicit time integration scheme, but it does not ensure a high accuracy on spring vibration behavior. Only two time steps are available during one vibration period of a free spring. To reproduce the true sinusoidal behavior, reduce the time step by a factor of at least 5. If the spring is used to connect two parts together, the spring vibration period increases and the default spring time step ensures stability and accuracy.
Figure 2. Co-linear Forces in Spring TYPE4
Figure 3. Instability of a Zero Length Spring
For further information, refer to the Radioss Theory Manual.
