OS-E: 0890 Maximum Bead Width Constrain for Topology Optimization of Oil Pan
Maximum bead width constraint is implemented to prevent the formation of large beads during topography optimization.
Model Description
- Objective
- Maximize the first normal mode frequency
- Constrains
- Maintain the beadfrac response within the range 0.5 to 0.8
- Design Variables
- Topography
Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/71_Oilpan_Max_bead_width.fem
