MV-8000: Open Loop Events
In this tutorial, you will learn how to assemble the vehicle for full vehicle simulations using Assembly Wizard and how to attach the driver using Task Wizard.
The Altair Driver is a set of MotionView models and libraries that allow MotionView users to control and script vehicle events.
Event example include the following:
  • Constant Radius Cornering
  • Single Lane Change
  • Double Lane Change
  • User Defined Path Following
  • Fish Hook Event, etc.
This is achieved by creating an interface to the five vehicle inputs:
  • Steering
  • Throttle
  • Gear
  • Brake
  • Clutch
You can use the Altair Driver to simulate any number of full vehicle events using multiple features:
  • Scripting: break up the simulation into different maneuvers; select the controllers for vehicle inputs and define conditions that end each maneuver.
  • Open-loop, closed-loop, and user-defined controllers to control.
    • Longitudinal speed or acceleration.
    • Vehicle path or lateral acceleration.
  • Switching controllers during a simulation.
  • Defining path and speed profiles parametrically, in a table, or by referencing a data file.
Assemble the Vehicle
In this step, you will assemble the vehicle using the Assembly Wizard.
  1. Start a new MotionView session.
  2. Ensure the MBD-Vehicle Dynamics Tools preference file loaded is for all of the MotionView functionality of the Advanced Driver to work properly.
  3. From the menu bar, select Model > Assembly Wizard.
    Figure 3.
    In Script an Open Loop Acceleration Event, a linear torque map powertrain will be used to avoid the complexity of adding controllers for gear and clutch.
  4. Select the Full vehicle with advanced driver option.
    This takes care of all the dependencies of the advanced driver.
    Figure 4.
  5. Click Next.
  6. Choose the default selections in the following Assembly Wizard pages.
    Page Label Selection Default (Yes/No)
    1 Model type Full vehicle with driver No
    2 Driveline configuration Front wheel drive Yes
    3 Vehicle body Body Yes
    4 Instrumentation Instrumentation Yes
    5 Front subframe None Yes
    6 Front suspension Frnt macpherson susp (1 pc. LCA) Yes
    7 Steering Linkages Rackpin steering Yes
    8 Rear subframe None Yes
    9 Rear suspension Rear quadlink susp Yes
    10 Powertrain Linear torque map powertrain Yes
    11 Signal generator Driver signal generator Yes
    12 Tires Auto Tires Yes
    13 Steering column Steering column 1 (not for Abaqus) Yes
    14 Steering boost None Yes
    15 Front struts Frnt strut (with inline jts) Yes
    16 Front stabilizer bars None Yes
    17 Rear struts Rear strut (with inline jts) Yes
    18 Rear stabilizer bars None Yes
    19 Front jounce bumpers None Yes
    20 Front rebound bumpers None Yes
    21 Rear jounce bumpers None Yes
    22 Rear rebound bumpers None Yes
    23 Disk brakes Disk brakes Yes
    24 Front Driveline Independent fwd Yes
    25 Driver System Altair Driver Yes
    26 Next Finish No
Add Driver Analysis
In this step, you will use the Task Wizard to load the driver analysis.
  1. From the menu bar, select Analysis > Task Wizard.
    Figure 5.
  2. Select AltairDriverFile from the Type drop-down menu.
    Figure 6.
    Tip:
    Selecting (Altair Driver icon) will open up the Altair Driver panel. This automatically resolves all of the vehicle attachments for the Altair Driver.
    Figure 7.
    Selecting the AltairDriverFile 0 will open up the driver event panel. Selecting the Event Editor button will open the Altair Driver File dialog.
The Altair Advanced Driver is added to the browser tree.
Write an Altair Driver File Driving Event
In this step, you will script an open loop acceleration, open loop sinusoidal steering, and an open loop driven braking event.
Driver requires an event script or the Altair driver file (ADF) to run any driving event. ADF can be edited using any text editor or by clicking the Edit Driver File button on the driver panel.
In this step, you will script an event with 50% throttle, 0% brake and 0 steering angle.
An event can be broken down into smaller sub-events or maneuvers. You will model this as a single maneuver event.
Figure 8.
  1. Open any text editor and copy and paste the following text into it.
    Important: All blank lines must be removed prior to saving the file.
    Tip: Read through the comments for a better understanding of what is written in the ADF.
    $-----------------------------------------------------------------ALTAIR_HEADER
    $ This block is required for version control
    [ALTAIR_HEADER]
    FILE_TYPE 		= 'ADF'
    FILE_VERSION 	= 1.0
    FILE_FORMAT 	= 'ASCII'
    $--------------------------------------------------------------------------UNITS
    $In this block we specify the units in which this file should be read
    [UNITS]
    (BASE)
    {length  force      	angle       mass   time}
    'meter'   'newton'   	'radians'  'kg'      'sec'
    $--------------------------------------------------------------------VEHICLE_IC
    $In this block we specify the initial conditions specifically initial speed of the
    $vehicle with respect to the vehicle IC marker in the driver attachments
    [VEHICLE_INITIAL_CONDITIONS]
    VX0 = -20.0
    VY0 = 0.0
    VZ0 = 0.0
    $--------------------------------------------------------------STEERING_STANDARD
    $This block specifies the saturation and cutoff frequency for the low pass filter for
    $steering output signal. These signals are global and are active for the entire event
    [STEER_STANDARD]
    MAX_VALUE 			= 3.141593
    MIN_VALUE 			= -3.141593
    SMOOTHING_FREQUENCY 	= 10.0
    INITIAL_VALUE 		= 0.0
    $--------------------------------------------------------------THROTTLE_STANDARD
    $throttle output signal
    [THROTTLE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.00
    INITIAL_VALUE 		= 0.5
    $---------------------------------------------------------------BRAKING_STANDARD
    $brake output signal
    [BRAKE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.0
    INITIAL_VALUE 		= 0.0
    $-----------------------------------------------------------------MANEUVERS_LIST
    $This block provides the list of all the maneuvers, simulation time for each maneuver
    $maximum solver step size (hmax) and print interval
    [MANEUVERS_LIST]
    { name       		simulation_time  h_max  print_interval}
    'MANEUVER_1'	5.0                     0.01     0.01
    $---------------------------------------------------------------------MANEUVER_1
    [MANEUVER_1]
    $This block provides the ties controllers to each driver output
    TASK = 'STANDARD'
    (CONTROLLERS)
    {DRIVER_SIGNAL  	PRIMARY_CONTROLLER 	ADDITIONAL_CONTROLLER}
     STEER                   	OL_STEER_0	  		NONE
     THROTTLE             	OL_0.5	  		NONE
     BRAKE                   	OL_0	  			NONE
    $---------------------------------------------------------OL_STEER
    $This is controller block containing all the information required by
    $the driver to construct the controller. Different controllers have
    $different requirements. Here we are using open loop constant type
    $of controller.
    [OL_STEER_0]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.0
    $---------------------------------------------------------OL_BRAKE
    [OL_0]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.0
    $---------------------------------------------------------OL_THROTTLE
    [OL_0.5]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.5
  2. Save the file.
  3. Source the file in the Altair Driver File browser.
    Figure 9.
    Note: The Edit driver file button can be used to edit the file.
  4. Click to run the simulation.
  5. After the simulation is over and the solver creates the h3d and plt files, from the menu bar, click Analysis > View Reports.
    Figure 10.
  6. Select the recent run in the View Reports dialog and click OK.
    Figure 11.
  7. The noise in the steering is numerical error of negligible magnitude – 0 for all practical purposes. Throttle is constant at 0.5 (driver throttle, brake and clutch outputs are normalized so, 50%) and brake is constant at 0.
    Figure 12.
  8. Next we will try slightly different initial conditions. We will start the throttle at 0 and brake at 100%. Click the Edit Driver File button to open up the file editor.
  9. Change the INITIAL_VALUE attribute in the THROTTLE_STANDARD block in the ADF, from 0.5 to 0.
    [THROTTLE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.00
    INITIAL_VALUE 			= 0.5 0
  10. Similarly, change the INITIAL_VALUE attribute in the BRAKE_STANDARD block in the ADF, from 0.0 to 1.0.
    [BRAKE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.0
    INITIAL_VALUE 			= 0.0 1.0
  11. Save the ADF.
  12. Run the simulation and study the results.
  13. Now, we see that throttle and brake start from respective initial values and step up to the controller outputs. The time taken to step up is roughly (5x1/SMOOTHING_FREQUENCY).
    Figure 13.
Model an Open Loop Sinusoidal Steering Event
In this step, you will model a simple event with constant 20% throttle, constant 0% throttle and sinusoidal steering input with amplitude of 60 degrees (∏/3 radians) and frequency of 0.5 Hz.
     [ALTAIR_HEADER]
    FILE_TYPE 		= 'ADF'
    FILE_VERSION 	= 1.0
    [UNITS]
    (BASE)
    VX0 = -20.0
    VY0 = 0.0
    VZ0 = 0.0
     [STEER_STANDARD]
    INITIAL_VALUE 		= 0.0
     [THROTTLE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.00
    INITIAL_VALUE 			= 0.2
     [BRAKE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.0
    INITIAL_VALUE 			= 0.0
     [MANEUVERS_LIST]
    'MANEUVER_1'		10.0                     0.01     0.01
    [MANEUVER_1]
    TASK = 'STANDARD'
    (CONTROLLERS)
     STEER                   	OL_STEER	  		NONE
     THROTTLE             	OL_THROTTLE  		NONE
     BRAKE                   	OL_BRAKE  			NONE
    $---------------------------------------------------------OL_STEER.
    $SIGNAL_CHANNEL tells the driver which solver variable in Signal Generator to over-ride
    $with the EXPRESSION value. The EXPRESSION should be consistent with MOTIONSOLVE.
    [OL_STEER]
    TAG			 = 'OPENLOOP'
    TYPE			= 'EXPRESSION'
    SIGNAL_CHANNEL 	  = 0
    EXPRESSION 	      = 'DTOR(60)*SIN(2*PI*0.5*TIME)'
    [OL_THROTTLE]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.2
    [OL_BRAKE]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.0
    Figure 14.
Model an Open Loop Curve Driven Braking Event
In this step, you will model a simple event with braking signal as a curve.
Figure 15.
  1. Open text editor and copy and paste the following text into it.
    Important: All blank lines must be removed prior to saving the file!
     [ALTAIR_HEADER]
    FILE_TYPE 		= 'ADF'
    FILE_VERSION 	= 1.0
    [UNITS]
    (BASE)
    VX0 = -20.0
    VY0 = 0.0
    VZ0 = 0.0
     [STEER_STANDARD]
    INITIAL_VALUE 		= 0.0
     [THROTTLE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.00
    INITIAL_VALUE 			= 0.0
     [BRAKE_STANDARD]
    MAX_VALUE 			= 1.0
    MIN_VALUE 			= 0.0
    INITIAL_VALUE 			= 0.0
     [MANEUVERS_LIST]
    'MANEUVER_1'		10.0                   0.001     0.01
    [MANEUVER_1]
    TASK = 'STANDARD'
    (CONTROLLERS)
     STEER                   	OL_STEER	  		NONE
     BRAKE                   	OL_BRAKE  			NONE
    [OL_STEER]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.0
    [OL_THROTTLE]
    TAG	= 'OPENLOOP'
    TYPE	= 'CONSTANT'
    VALUE	= 0.0
    [OL_BRAKE]
    TAG	= 'OPENLOOP'
    TYPE	= 'CURVE'
    BLOCK	= 'BRAKE_CRV'
    $---------------------------------------------------------CURVE_DATA
    [BRAKE_CRV]
    INDEPENDENT_VARIABLE 	= 'TIME'
    DEPENDENT_VARIABLE		= 'BRAKE_SIGNAL'
    INTERPOLATION			= 'LINEAR'
    {TIME	BRAKE_SIGNAL}
    0	0
    1	0
    2	0.2
    3	0.5
    4	0.8
    5   1.0
    6   1.0
    7   0
    10  0
    Figure 16.
