Messaging
Model ElementThe Messaging element allows you to control how MotionSolve generates messages.
<Messaging>
log_option = { "Overwrite" | "ScreenOnly" | "Append" }
usrsub_param_string = "USER([[par_1[,...][,par_n]])"
usrsub_dll_name = valid_path_name
usrsub_fnc_name = "MESSAGE_SUB"
</MESSAGING>Attributes
- log_option
Select from Overwrite, ScreenOnly, and Append.
- Overwrite
- Specifies whether the LOG file should be overwritten.
- ScreenOnly
- the messages should be sent only to the computer screen.
- Append
- Whether the log file should be appended to.
- usrsub_param_string
- The list of parameters that are passed from the data file to the user written subroutine, MESSAGE_SUB.
- usrsub_dll_name
- Specifies the path and name of the DLL or shared library containing user subroutine. MotionSolve uses this information to load the user subroutine in the DLL at run time.
- usrsub_fnc_name
