Control: SISO
Model ElementControl_SISO is an abstract modeling element that defines a linear, time invariant dynamic system in the Laplace domain. SISO stands for Single Input Single Output.
Such a dynamic system is characterized by a transfer function. In practice, the transfer function is often characterized by experiments followed by curve fitting. Modeling applications of this element include actuators (electrical, hydraulic, and pneumatic), vibration isolators (bushings and shock absorbers), and controllers (PID).
You specify the Control_SISO element by specifying the coefficients of the numerator and denominator polynomials that define the transfer function, along with one input (u) variable and one output (y) variable. This is shown in the block diagram in the image below.
Figure 1. Block Diagram Representation of the Control_SISO Element
U(s) and Y(s) represent the Laplace transforms of the time domain input and output variables and G(s) represents the transfer function given by:(1)
G(s)= Y( s ) U( s ) = b 0 + b 1 s 1 ++ b m s m a 0 + a 1 s 1 ++ a n s n
m and n denote the order of the numerator and denominator polynomials and must satisfy m ≤ n.
MotionSolve internally converts this Laplace domain element into the following time domain system of first order differential equations:(2)
x ˙ ( t ) = A x ( t ) + B u ( t ) y ( t ) = C x ( t ) + D u ( t )
x is the state vector, u is the input variable, and y is the output variable. A, B, C, and D denote the state matrix, the input matrix, the output matrix, and the direct feed-through matrix, respectively. The initial conditions for x are assumed to be zero. The equations above are said to be in the state space form and are depicted schematically in the image below.
Figure 2. Input, Output, and States for a Dynamic System
<Control_SISO
       id                     = "integer"
     [ label                  = "string" ]
       x_array_id             = "integer"
       y_array_id             = "integer"
       u_array_id             = "integer"
     [ is_static_hold         = { "TRUE"  |  "FALSE" }  ]
       num_numerator_coef     = "integer"
       numerator_coef         = "real [ real real  …  real ] "
       num_denominator_coef   = "integer"
       denominator_coef       = "real [ real real …  real ] "
Attributes
id
Element identification number (integer>0). This number is unique among all Control_SISO elements.
label
The name of the Control_SISO element.
x_array_id
Specifies the ID of the Reference_Array used to store the states x of this Control_SISO. You can use the ARYVAL() function with this ID to access the states in a MotionSolve expression. You can also use this ID in SYSFNC and SYSARY to access the state values from a user subroutine.
y_array_id
Specifies the ID of the Reference_Array used to store the output, y, of this Control_SISO. You can use the ARYVAL() function with this ID to access the states in a MotionSolve expression. You can also use this ID in SYSFNC and SYSARY to access the output values from a user subroutine.
u_array_id
Specifies the ID of the Reference_Array used to store the input u of this Control_SISO. You can use the ARYVAL() function with this ID to access the states in a MotionSolve expression. You can also use this ID in SYSFNC and SYSARY to access the input values from a user subroutine.
is_static_hold
num_numerator_coef
An integer that specifies the number of coefficients in the numerator of the Control_SISO. num_state > 0.
numerator_coef
Specifies the coefficients, in the ascending powers of "s", of the numerator polynomial of the transfer function.
An integer that specifies the number of coefficients in the denominator of the Control_SISO. num_numerator_coefnum_denominator_coef.
denominator_coef
Specifies the coefficients, in the ascending powers of "s", of the denominator polynomial of the transfer function.
Consider the problem of maintaining a reference speed of a rotor in the presence of disturbance loads. A block diagram of the control system is shown in the image below.
Figure 3. Block Diagram for a Rotor Speed Control System
  • Ω denotes the reference speed.
  • Ω denotes the actual speed.
  • E(s) denotes the Laplace transform of the error signal.
  • Gc(s) denotes the controller transfer function.
  • T(s) denotes the output of the controller, the control torque.
  • J denotes the moment of inertia of the rotor.
  • N(s) denotes the disturbance load in the Laplace domain.
One solution is to design a proportional integral (PI) controller (Ogata, 1995) with transfer function given by:(3)
G c (s)= T(s) E(s) = K+ K p s s
K and Kp denote the controller gains. This controller can be modeled using the Control_SISO as follows:
<Control_SISO
     id                   = "303001"
     label                = "ControlSISO name"
     x_array_id           = "30300200"
     y_solver_id          = "30300300"
     u_solver_id          = "30300100"
     is_static_hold       = "FALSE"
     num_numerator_coef   = "2"
     numerator_coef       = "10. 1."
     num_denominator_coef = "2"
     denominator_coef     = "0. 1."
This example is described in detail in MV-7003: Simulating a Single Input Single Output (SISO) Control System Using MotionView and MotionSolve. The image below, taken from the tutorial, shows the plot of a rotor speed versus time.
Figure 4. Plot of Rotor Speed versus Time
  1. Control_SISO is a versatile element that has many different applications in modeling multi-disciplinary systems. This element may be used to model any externally-defined subsystem that can be characterized by a transfer function.
    Some examples of subsystems that could be "integrated" into a system model in MotionSolve include:
    • PID and other controllers
    • Hydraulic, pneumatic, and electromechanical actuators
    • First order delay elements
    • Simple driver models that mimic human driving behavior
    • Frequency and amplitude dependent properties of vibration isolators
  2. Note that the algorithm that transforms the Laplace domain transfer function into time domain state space form is not robust for higher order systems. In such cases, we recommend first factoring the transfer function into lower order ones and then using one Control_SISO element for each factor.
  3. The behavior of the dynamic states associated with a Control_SISO element during static and quasi-static solutions is governed by the attribute, is_static_hold.
    is_static_hold = "TRUE"
    If the solution is done at time T = 0, the states are kept fixed at the value specified by the IC array. If the solution is being done after a dynamic analysis, then the value is kept fixed at the last value obtained from a dynamic simulation. The equations defining the states for the Control_SISO are replaced with the following:
    x(t*) = x*, where x* is a constant.
    Note that when the dynamic states are kept fixed, their time derivatives no longer are zero at the end of the static equilibrium or a quasi-static step. The inputs u will have changed. This may lead to transients in the solution if a dynamic solution were to be subsequently performed.
    The states are not kept constant, but allowed to change as the configuration of the entire system changes during the solution process. Here is how this is accomplished:
    For static and quasi-static solutions, the derivative of the dynamic states is set to zero. This converts the Control_SISO to a set of algebraic equations for these two analyses.
    The differential equations become:
    Ax+Bu=0
    During the equilibrium solution, the input u changes as the system changes its configuration to meet the equilibrium conditions. The above equations are solved to compute x for the current value of u.
    This method ensures that the time derivative of the dynamic states is zero at the end of the static or quasi-static solution and ensures a smooth subsequent dynamic analysis.
