Post: User Output Request
Model ElementThe Post_UserAPI element allows you to generate your own results file.
<Post_UserAPI>
     USRSUB_PARAM_STRING = "USER( [[par_1 [, ...][,par_n]] )"
     USRSUB_DLL_NAME     = valid_path_name
     USRSUB_FNC_NAME     = custom_fnc_name >
     SCRIPT_NAME         = valid_path_name
     INTERPRETER         = "PYTHON" | "MATLAB"
     USRSUB_PARAM_STRING = "USER([[par_1[,...][,par_n]])"
     USRSUB_FNC_NAME     = "custom_fnc_name" >
</Post_UserAPI>
Attributes
usrsub_param_string
The list of parameters that are passed from the data file to the user written subroutine Message_Sub.
usrsub_dll_name
Specifies the path and name of the DLL or shared library containing user subroutine. MotionSolve uses this information to load the user subroutine in the DLL at run time.
usrsub_fnc_name
Specifies an alternative name for the user subroutine POST_SUB.
script_name
Specifies the path and name of the user written script that contains the routine specified by usrsub_fnc_name.
interpreter
Specifies the interpreted language that the user script is written in. Valid choices are MATLAB or PYTHON.
