To Find Connected Entities
  1. From the Macros menu, select Find Connected Entities.
    The Find Connected Entities panel is displayed.
  2. Under Find Entities Connected to, select the desired entity (Body, Joint, or Bushing).
  3. Click on the "entity" input collector.
    The body, joint, or bushing dialog is displayed.
  4. Select the desired entity from the dialog and click OK.
    The attached objects are highlighted in the graphics area and listed in the text box (on the right side of the panel).
