poIVectorDefine SetShowMidsideNodeResults
Sets the show midside node results state.
poIVectorDefine_handle SetShowMidsideNodeResults showMSN
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the show midside node results state for this result definition.
Note: The result definition can only be modified if it not cached.
showMSN
True to show midside node results, false to not show midside node results.
To set the show midside node results state to false:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle vdefine 3 vector
vdefine SetShowMidsideNodeResults false
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
