poITrackingSystem GetID
Gets the tracking system's ID.
poITrackingSystem_handle GetID
HyperView Tcl Query
This command retrieves the tracking system's ID.
None.
View new features for HyperWorks Desktop 2021.1.
Gets whether clipped geometry should be displayed as transparent.
Gets the tracking degree of freedom.
Gets the tracking system label.
Gets the IDs of the tracking node and the model ID of the tracking system.
Gets the IDs of the tracking plane's nodes and model IDs of the tracking system.
Gets a node string for the given index of the current tracking plane.
Gets the plane type of a tracking system.
Gets the list of valid plane types for a tracking system.
Gets the tracking system state.
Gets the value of the "Align with global" option.
Sets whether the clipped geometry should be displayed as transparent.
Sets the tracking degree of freedom.
Sets the system's ID visibility.
Sets the tracking system label.
Sets the tracking node and model IDs.
Sets the tracking plane's nodes and model IDs.
Sets the one of the tracking plane's node specified by the index.
Sets the plane type for a tracking system.
Sets the value of the "Align with global" option (On/Off).
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
