poITracingCtrl GetThickness
Gets the node trace line thickness.
poITracingCtrl_handle GetThickness
HyperView Tcl Query
This command retrieves the node trace line thickness.
None.
View new features for HyperWorks Desktop 2021.1.
Adds an entity to the tracing control.
Adds a node to the tracing control.
Adds a part to the tracing control.
Adds a simulation step index to the list of simulation steps that are traced.
Gets the base time of the line tracing.
Gets the node trace line color.
Gets the entity color.
Gets the list of node's that are being traced.
Gets the available entity types.
Gets the list of nodes that are being used for line tracing.
Gets the node trace mode.
Gets the valid list node/component trace modes.
Gets the list of nodes that are being traced.
Gets the number of entities of the given type.
Gets the node trace number of steps.
Gets the list of part IDs that are being traced.
Gets the list of simulation traced steps.
Removes an entity from the tracing control.
Removes a node from the tracing control.
Removes a part from the tracing control.
Removes a simulation step index from the list of simulation steps that are traced.
Sets the node trace line color.
Sets the entity color.
Sets the node trace line thickness.
Sets the node trace mode.
Sets the number of traced steps.
HyperView Tcl Query
None.
