poIResultCtrl GetLayerFilterList
Gets the handle for a layer filter.
poIResultCtrl_handle GetLayerFilterList "list"
HyperView Tcl Query
This command retrieves a list of all layer filter IDs associated with the result control.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
variable filter_ids
result_handle GetLayerFilterList filter_ids
foreach filter $filter_ids {
result_handle GetLayerFilterHandle filter_handle $filter
filter_handle GetLabel filter_label
hwi CloseStack
Returns an error if the result controller handle is invalid.
