poIQueryIgnoreElemTypeRule GetElementTypeList
Gets the element type list from the advanced query.
rule_handle GetElementTypeList
HyperView Tcl Query
This command is used to get the element config type list from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule ignoreelemtype]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetElementTypeList "rigidlink Quad4"
hwi CloseStack
This command returns HW_InvalidHandle
, if the core object associated with
the advanced query handle does not exist anymore.
