poIIsoValueCtrl GetLayer
Gets the current layer label.
poIIsoValueCtrl_handle GetLayer
HyperView Tcl Query
This command retrieves the current layer label
Returns the layer string.
View new features for HyperWorks Desktop 2021.1.
Exports an STL format ASCII file.
Gets the nodal variation factor.
Gets the method by which elemental results are averaged to nodes.
Gets the list of possible averaging modes.
Gets the state of the average across parts.
Gets the output/contour binding of the current request.
Gets the iso surface color value.
Gets the state of color override option for the iso value.
Gets the corner data enabled state.
Gets the current data component for the given dimension.
Gets the current iso value data type.
Gets the dimension state: enabled or disabled.
Gets the current display mode.
Gets the pool state, either enabled or disabled.
Gets the auto load/unload iso value data state.
Gets the angle set for the feature angle average.
Gets the state of the feature angle average.
Gets the state of the "Ignore Flipped Normal" option set for the feature angle average.
Gets the current iso value increment.
Gets the current iso value.
Gets the maximum iso value possible.
Gets the minimum iso value possible.
Gets the current legend mode.
Gets the projection rule associated with the iso controller.
Gets the result system ID.
Gets the set handle from the iso controller.
Gets the set size of the iso controller.
Gets the current shell layer label.
Gets the state of the "Show Midside Node Results" option for the iso control.
Sets the nodal variation factor's valid range.
Sets the method by which elemental results are averaged to nodes.
Sets the state of the average across parts.
Sets the iso surface color value.
Sets the state of color override option for the iso value.
Enables node on element data.
Sets the data component for a given component.
Sets the data type for the iso control.
Sets the dimension state: enabled or disabled.
Sets the current display mode.
Sets the dimension state, either enabled or disabled.
Sets the auto load/unload iso value data state.
Sets the angle for the feature angle average.
Sets the state of the feature angle average.
Sets the state of the "Ignore Flipped Normal" option for the feature angle average.
Sets the current iso value increment.
Sets the iso value to the specified value.
Sets the current layer.
Sets the legend mode to true or false.
Sets the projection rule for projecting 3D tensors to the 2D element plane.
Sets the result system ID.
Sets the selected entities to be used by the iso control.
Sets the current shell layer.
Sets the state of the "Show Midside Node Results" option for the iso control.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
