poIExplosion GetLabel
Gets the explosion label.
poIExplosion_handle GetLabel
HyperView Tcl Query
This command returns the explosion label.
Error
Returns the explosion label, or 0 if an error occurred.
View new features for HyperWorks Desktop 2021.1.
Gets the translation direction.
Gets the explosion ID.
Gets a list of possible origin options.
Resets the exploded/translated parts back to their original position.
Sets the translation direction.
Sets the translation direction along a vector defined by at least two nodes.
Sets the explosion label.
Sets the mode to either explode or translate selected parts.
Specifies the selected components to be used by the control.
Applies the changes to the selected part to be exploded or translated.
HyperView Tcl Query
