pltIEdit GetToValue
Gets the maximum value of the edited range.
pltIEdit_handle GetToValue
HyperWorks Tcl Query
Returns the maximum value of the edited range.
None.
View new features for HyperWorks Desktop 2021.1.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the type of the edit.
ON THIS PAGE
None.
ON THIS PAGE
