pltIEdit GetOrientation
Gets the orientation of the edit.
pltIEdit_handle GetOrientation
HyperWorks Tcl Query
- horizontal
- vertical
None.
View new features for HyperWorks Desktop 2021.1.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
ON THIS PAGE
None.
ON THIS PAGE
