Adding a Static Overlay Image
Overlay an image on a graph. The image can either be a 3D view or imported from a file.
Select the graph to which you want to add the image.
  1. On the Display tab, in the Image group, click the  Chart image icon.
  2. From the drop-down list, select one of the following: an image from the 3D result view (if available) or select Import file under Existing image.
    • To add an image of the 3D view to the graph, select the relevant  3D view.
    • To import an image from a file, select  Import file.
    Figure 1. A Cartesian graph with overlay image of the 3D view. The image was moved to the top-left.
