Launching POSTFEKO (Linux)
There are several options available to launch POSTFEKO in Linux.
- Open POSTFEKO using the Launcher utility.
- Open a command terminal. Launch POSTFEKO
using the absolute path to the executable in the installation, for
example:
/home/user/2021.1/altair/feko/bin/postfeko
- Open a command terminal. Source the “initfeko” script using the absolute path to
it, for
example:
Sourcing initfeko ensures that the correct Feko environment is setup. Type postfeko and press Enter.. /home/user/2021.1/altair/feko/bin/initfeko
Note: Take note that sourcing a script requires a dot (".") followed by a space (" ") and then the path to initfeko in order for the changes to be applied to the current shell and not a sub-shell.
