Edge-Fed, Planar Multilayer Substrate Model
Model a microstrip patch antenna using an edge feed and a planar multilayer substrate (Green’s functions). The patch antenna is solved with MoM.
To improve accuracy, the edge port length should be less than 1/30 of a wavelength. For this example, 1/30 of a wavelength relates to a maximum edge port length of 3 mm. As this example is only for demonstration purposes, an edge length of 4.5 mm is used instead.
![](../../../../images/feko/example_guide/EG_A08_patch_microstrip_rect/intro_edge_greens.png)
Figure 1. A 3D view of the edge-fed microstrip patch antenna on an infinite ground with symmetry in CADFEKO.
