Dielectric Resonator Antenna on Finite Ground
Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
- Feed with a FEM modal source and solve using the hybrid finite element (FEM) and MoM solution.
- Feed with a waveguide source and solve using the method of moments (MoM) solution with the surface equivalence principle (SEP).
![](../../../../images/feko/example_guide/EG_A12_dra_finite_ground/intro.png)
Figure 1. A 3D view wire frame view of the dielectric resonator antenna on a finite ground plane in CADFEKO.
