Viewing the Results
View and post-process the results in POSTFEKO.
- The single patch antenna model includes the mutual coupling between the elements as if the patch antenna is in an infinite array.
- The gain is about 20 dB higher for the 10x10 element array than for the single element.
![](../../../../images/feko/example_guide/EG_A16_patch_array_pbc/graph_ff_broadside.png)
Figure 1. The far field gain for a single element and a 10×10 element patch array in the broadside direction.
![](../../../../images/feko/example_guide/EG_A16_patch_array_pbc/graph_ff_squint.png)
Figure 2. The far field gain for a single element and a 10×10 element patch array in the 20° squint direction.
