Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the model unit to centimeters.
Define the following variables.
- epsr_a = 10.2 (The relative permittivity of the bottom layer.)
- epsr_b = 2.54 (The relative permittivity of the top layer.)
- f_min = 2.1e9 (The minimum frequency.)
- f_max = 2.3e9 (The maximum frequency.)
- lambda_a = c0/f_max/sqrt(epsr_a)*100 (The wavelength in the bottom layer.)
- lambda_b = c0/f_max/sqrt(epsr_b)*100 (The wavelength in the top layer.)
- d_a = 0.16 (The height of the bottom layer.)
- d_b = 0.16 (The height of the top layer.)
- patch_l = 4.0 (The length of the patch antenna.)
- patch_w = 3.0 (The width of the patch antenna.)
- grnd_l = 2*patch_l (The length of the substrate.)
- grnd_w = 2.5*patch_w (The width of the substrate.)
- feed_l = lambda_a (The length of the microstrip feed line.)
- feed_w = 0.173 (The width of the microstrip feed line.)
- stub_l = 1.108 (Length of the matching stub on the microstrip feed line.)
- ap_l = 1.0 (The length of the aperture.)
- ap_w = 0.11 (The width of the aperture.)
Create a dielectric medium, bottom_layer.
- Relative permittivity: epsr_a
- Dielectric loss tangent: 0
- Label: bottom_layer
Create a dielectric medium, top_layer.
- Relative permittivity: epsr_b
- Label: top_layer
Create the aperture.
Create a rectangle.
- Definition method: Base centre, width, depth.
- Base centre (C): (0, 0, 0)
- Width (W): ap_l
- Depth (D): ap_w
- Label: aperture
Create a rectangle.
Create the finite ground plane.
Create a rectangle.
- Width (W): grnd_w
- Depth (D): grnd_l
- Label: ground
Create a rectangle.
Create the aperture in the ground.
- Subtract aperture from ground.
- Rename Subtract1 to slotted_ground.
The finite ground plane now has a hole at the centre where the aperture plate was defined. -
Create the patch.
Create a rectangle.
- Base centre (C): (0, 0, d_b)
- Width (W): patch_w
- Depth (D): patch_l
- Label: patch
Create a rectangle.
Create the microstrip feed line.
Create a rectangle.
- Definition method: Base corner, width, depth
- Base corner (C): (-feed_w/2, -feed_l/2 + stub_l, -d_a)
- Width (W): feed_w
- Depth (D): feed_l
- Label: feed
Create a rectangle.
An edge feed will be used to excite the model.
Create a plate (via) that connects the ground plane and feed line.
Create a rectangle at the end of the feed line in the XZ plane.
- Change the workplane origin to (-feed_w/2, feed_l/2 + stub_l, -d_a).
- Rotate the workplane by 90° around the U axis to create the rectangle in the XZ plane.
- Base corner (C): (0, 0, 0)
- Width (W): feed_w
- Depth (D): d_a
- Label: feedPort
A positive terminal and a negative terminal are required for the edge source.
Split feedPort in the UV plane at (0, 0,
-d_a/2).
- Rename the two resulting components to port_bottom and port_top.
- Union the parts and rename the resulting part to conducting_elements.
Set all faces to PEC.
Note: This step ensures that the faces will remain PEC after future union operations.
Create the bottom dielectric layer.
Create a cuboid.
- Base centre (C): (0, 0, -d_a)
- Width (W): grnd_w
- Depth (D): grnd_l
- Height (H): d_a
Create a cuboid.
Create the top dielectric layer.
Create a cuboid.
- Width (W): grnd_w
- Depth (D) (H): grnd_l
- Height: d_b
- Label: top_layer
Create a cuboid.
- Union all parts.
- Set the region of the bottom layer to bottom_layer.
- Set the region of the top region to top_layer.
Add an edge port between the two split components of
feedport.
- The positive face correspond to the face attached to the ground plane.
- The negative face correspond to the face adjacent to the positive face.
- Create a voltage source. Add a voltage source to the port. (1 V, 0°, 50 Ω).
- Set a continuous frequency range from f_min to f_max.
Specify the symmetry about the X=0
plane as Magnetic symmetry.
Tip: Exploit model symmetries (if it exists) in a large or complex model to reduce computational costs.
