Adding a Voltage Source
Add a voltage source to the port of the dipole.
On the Source/Load tab, in the
Sources on ports group, click the
Voltage source icon.
On the Add voltage source dialog, use the default
settings.
Click Create to create the voltage source and to
close the dialog.
Note: Adding the source should change the Construction tab to the Configuration tab where, for example, the sources, loads and frequency are set.
