Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Create a job profile, a customized shortcut for submitting a job.
Open the Windows system tray and double-click the Access Desktop icon
If you submit multiple jobs to the same application with the same arguments, it makes sense for
you to create a job profile that has these arguments pre-populated for you,
streamlining the process of job submission.
Click .
Select Show Job Profiles.
A list of solvers (Type = Application) and job profiles (Type = Profile)
are displayed.
Double-click a solver.
A job submission form is displayed containing the solver arguments.
Choose which cluster to add the job profile to by clicking the
Select server menu and selecting a cluster.
Populate the solver arguments with values.
When you use a job profile to submit a job, solver arguments may be modified before the job is
submitted. You can override any values that have been saved in the job
profile or you can populate arguments that were not populated while creating
the job profile.
Click Save As Profile.
Enter a name for the profile.
Click OK.
The job profile is saved and is displayed in the list.
