Feko 2017.2.3 Release Notes
Feko 2017.2.3 is a bug-fix update that includes the enhancements and bug fixes documented below.
Note: Feko 2017.2.3 is a cumulative update that contains changes from previous updates. It should be applied to an existing installation of Feko 2017 (that may or may not have been updated previously).
CADFEKO
Resolved Issue
  • An assertion failed with "getMeshElementDescriptors().count() == 1" when saving a model containing a suspect port connected to a general network or transmission line. The .pre file will now contain the error message "The mesh instance of port '[port label]' is suspect". (2017.2.3)
Solver
Resolved Issues
  • The linear system solution numerical libraries are reverted back to the previous version due to floating point exceptions encountered on some hardware platforms. (2017.2.3)
  • The first frequency impedance was incorrectly calculated for a multi-configuration problem run in parallel. (2017.2.3)
  • S-parameters were calculated incorrectly when adding reference impedances to existing loads at microstrip ports. (2017.2.3)
  • A division by zero error is avoided when requesting the scattered far field only for models that consist of sources only. (2017.2.3)
  • The performance of the initialisation phase for the windscreen solution method is improved. (2017.2.3)
  • Floating point exceptions that could have been raised on Linux systems using newer versions of glibc are resolved. (2017.2.3)
