Remove a Job
Remove old or unwanted jobs.
Only jobs that have completed or have failed can be removed. Removing a job, deletes the job from the PAS, but the job files will be available in PAS.
  1. Click the Jobs tab located in the upper left-hand of the page.
    The Job Monitoring view is displayed containing a list of the jobs that have been submitted.
    Tip: Use the filter on the left to view only completed or failed jobs.
  2. Right-click a completed or failed job.
    Tip: You can select multiple jobs to delete. Select the first job by clicking its name and hold down CTRLand select each job by clicking its name.
  3. Click Delete.
    The Delete Job dialog box is displayed.
    Figure 1. Delete Job
  4. Perform one of the following options:
    • Click Yes to remove the job.
    • Select Delete related folders and files in the staging area? check box and click Yes to remove the job from the staging area.
