Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Edit a profile and create a profile by editing an existing profile.
Click the Jobs tab located in the upper left-hand of the
page.
A list of applications are displayed at the top of the Job Monitoring
page.Figure 1. List of Applications/Solvers
Double-click an application.
A job submission form is displayed. Figure 2. Saved Job Profile
The following panes are displayed in the Job Submission form:
Left pane - Displays the list of Solvers based on the category and
Profiles pertaining to that Solvers. First time when you select an
Application, Generic Profile is selected and subsequent time Last
Submitted profile is selected.
Center pane - Displays the Job Submission Form.
Right pane - Displays the File Management section. You can perform all
the file related activities in this section. For example, selecting a
file as an input file or include files, selecting a directory as an
output directory, editing a file, uploading a files, searching a file
from the list.
Select the profile that you want to update from the left pane.
The job submission form of the profile will be displayed in the right
pane. Figure 3. Job Submission Form of the Profile
Edit the required solver arguments.
Note: Click Reset at the top right-hand corner of the job
submission form to reset the values of the application arguments.
Click Set Profile as Default to
set this profile as a default profile.
Choose one of the following options:
Click Save to save the updated profile.
Click Save As to create a new profile.
Note: If you click Save AS, a Save
Profile dialog box will be displayed to provide a profile
name.
