Default Roles and Resources
Overview of the default Access Web roles.
Access Web Roles
- Manager
- A Manager has the highest level of access privilege. Managers can add, edit, or remove clusters, can view and act upon jobs and files, and can grant and restrict access to the various features of Access Web. By default, the Service User entered during the installation of Access Web is assigned to the Manager role and cannot be removed from this role.
Privileges
- System Administrator
- This privilege allows user management activities like Create, Modify, and Delete Users. It also offers all functions available to Portal Administrator except Management of Roles and Privileges.
- Security Administrator
- This privilege allows full access to manage user access controls via roles and privileges.
- Audit Administrator
- This privilege allows read-only access to Audit Logs.
- Application User
- This privilege restricts application access for jobs, sessions and to the resources.
Resources
By default, the following resource levels are available:
- Applications
- This privilege allows access to the applications and its respective profiles available in Access Web. It limits the users to access applications for job submission, create job profiles, use the application for remote session and perform custom action.
