Tutorial: Running a Baseline Analysis
Run a baseline static analysis, then review and animate the results.
- Run a baseline static analysis
- View results for the factor of safety
- View results for displacement
- View results for von Mises stress
- View results for tension and compression
- Play an animation
Overview
In this tutorial, you will run a baseline static analysis of a part in a steady state and review the results.
- K: is the global stiffness matrix
- x: is the displacement vector response to be determined
- f: is the external forces vector applied to the structure
The following tutorial demonstrates how to run a baseline analysis in order to better understand what a static analysis is.
